My gaming rig:
Windows 10 Pro 64bit
CPU: Intel Core i5-3570K
GPU: Asus 1080 Ti Strix OC Edition
MOBO: Asus Sabertooth Z77
RAM: 16 GB of G.Skill Ripjaw-X DDR3 1600Mhz (XMP profile)
SSD: 256GB Crucial M4
HD: Western Digital Black 2TB
CPU Cooler: Noctua NH-D14
Case: Corsair CC600T Graphite White Special Edition
PSU: Corsair 850AX Gold
Monitor: Asus ROG SWIFT PG278Q 1440p 144 MHz + Nvidia G-Sync
TV: Samsung KS8500 65" 4K TV
AV-Receiver: Onkyo TX-NR-656 AV-Receiver
My PC suddenly won't power on.
I managed to get it to power on twice by doing a JUMPER CLEAR RTC RAM but after shutting it down it won't power down. The second time I got it to run and work for a long time, put it to sleep - and then when trying to wake it up - nothing happened and suddenly after a moment - the PC shut itself down. Without ever waking up.
I tried to reset bios settings. I tried doing the Jumper CLEAR RTC 3-4 times. It worked twice but inconsistently and now the issue is back.
I can't reach the battery to try and replace it - because of the DAMN Sabertooth "Thermal Armor" blocking the path to the battery... without taking the whole thing apart (the entire system piece by piece). Unless I will cut 2 cuts on the thermal armor to remove the plating covering the battery.
Not sure it's worth it.
I also tried to short circuit the power pins instead of the power button - didn't help. So it's not the power button's issue.
Yesterday the PC ran 100% and was super smooth and hitch free for hours. The PC is in great order and quite strong and fast and never made an issue before. This is all very sudden and unexplainable.
Please help.
What should I do?
Please help.
What should I do?
