Question Pc temps not showing
RistiK
41
Hey, I was wondering why any app on my pc won't show the temperature of my components anymore. It was working before and I tried many software but any one of them can't read my pc temperatures anymore. What can cause that? I have a 370-A II Prime and a i5-8600k and a gtx 1070
Hi, Same thing happened to me. Do you play Valorant? The Riot Vanguard anti-cheat system is the problem for me.
I managed to use a setting in MSI Afterburner showing again my GPU, allowing me to input my custom fancurve, again.
So, if you are using MSI Afterburner, you'll be able to see GPU temp and all by disabling the option "enable low-level I/O driver" .
EDIT: This action didn't work for CPU temps, something else must be blocking it because of Vanguard. RTSS only shows cpu usage for me.
