My Sony bravia will not come up in playback devices on my PC. (i have checked the boxes to show all)
If i unplug my headphones i get a red x on the speaker that says no audio output device installed.
My TV used to play sound and i cant figure out what changed.
My device manager only shows the headphones under the sound video and hardware tab.
With the headphones installed i also get a new section in my device manager labeled as audio inputs and outputs that list only the headphones under. If i unplug my headphones the Audio Inputs and Outputs disappears.
I bought a gateway dx 4885 ub3a which has the i5 4440 and i put an Geforce GTX 750 ti.
Its connected to my tv (which is the only monitor(tv) i have and only have used) via hdmi. Picture comes in flawlessly just no audio.
Also i had no audio before the graphics card. I installed the card for better graphics and hoping it would fix the audio problem, but no luck.
I've had this problem for 5 days now, searching through various forums and haven't had any luck to a solution.
Any help would be much appreciated as this is the first PC problem i have encountered that i couldn't fix myself. Thanks, Charlie and sorry if i posted in the wrong spot, not sure if this is a hardware or software issue
