PC turns itself off then on again. Help!
nmeadows
8
so when I turn my PC for the first time in a day it works for about 5 minutes then it turns itself off, (the LED's turn off, fans, everything). Then it turns itself on again but can only stay on for about 10 seconds then it turns off. On, off, on, off. No error message appeared. I asked my friend and he told me to re-install windows. I started to re-install it but then it turned itself off and when I boot it up windows trys to re-install immediately. Help me!!!!!!!!!!
specs..
CPU: Intel Ore i5-6600K 3.5GHz Quad-Core Processor
CPU Cooler: Hyper TX3 EVO
Motherboard: Gigabyte Z170XP-SLI
Memory: Corsair Vengeance LPX 2x8GB DDR4-2400MHz
Storage: Samsung 850 EVO-Series 250GB 2.5” Solid State Drive
Storage: Seagate Barracuda 2TB 3.5” 7200RPM Internal Hard Drive
GPU: ASUS Turbo Geforce GTX 970 4gb
Case: Graphite Series 230T Windowed Compact Mid-Tower Case Rebel Black
Power Supply: Corsair CX600M Modular
The fact that all your components seem fine yet your pc wont stay powered on is a good clue.
To check this, you can try a mate's power supply if he has one.
It's not too new. I put it together around 1 month ago and have used it plenty of times since.
Haven't overclocked at all. Are you sure the psu could be going bad? its pretty new
yeah ok. ill let you know how it goes!
