Hi, my PC boots up, display shows up, ram, gpu, cpu everything works but front and back panel fans do not run. Top fan runs flawlessly. When did it happen?
I opened the case, removed GPU, cleaned it with spectacle cloth, changed ram slot, unplugged HDD wire...boot up the pc, it did not boot up because of unplugged HDD even though I have windows on SSD. So I plug it back again but the fans do not run. I have tried unplugging cpu and system fan power and fan wires but I have no idea why they're lightning up but not spinning. And I have changed CMOS battery as well.
Specs:
GPU - RTX 2060
Processor - Ryzen 5 7600x
Mobo- Gigabyte B650m Gaming X AX
Ram - Adata 16gb 6000 MHz
PSU- Asus Tuf gaming 550w (less than a 9 month old)
Case- Galax Revolution 01
https://we.tl/t-cwPsjV1pHt
https://we.tl/t-HUmjdB0GQU
I have been having issues regarding mouse lag since 2019/2020. I built this new pc in Aug 2023 but the problem persists. Last time I opened this pc back in October 2023. Unplugging and pugging ram, then resetting bios, made mouse faster for some reason. I face power outage every now and then and mouse became slow and laggy again so I opened the case again but fans stopped working.
Specs:
GPU - RTX 2060
