So I was using my PC as usual one day and did the usual procedure of turning the system off because I needed to leave for work. Before this, the PC and the monitor was working perfectly fine. But when I got home from work and turned on the PC, the system itself turns on, lights on, fans spinning, usual noises being made. But the monitor stayed blank, saying that there is "no signal".
I have tried swapping cables and the monitor is still blank, I have tried plugging the cable into another monitor (it was a tv...) and it works fine. So I'm kind of assuming that the problem is with the monitor, but is there anything that I can still do to solve this? or is replacing the old monitor the only thing I can do?
