Pc turns on for a split second
probypro
7
Hi! This is my first post but im reading this forum before trying to find a solution but nothing works.
The problem is everytime i turn on my computer it only turns on for a split second. No beep.
I try to reseat all the components.
I also clear/reset cmos
I also remove ram, video card, etc in mobo leaving only mobo and psu but still turn on for a split second
Last week i bought a new 600w psu guessing that the problem is with the psu.
But my pc runs normal for only 2 days.
It back to its previous issue that turns on for a split second.
Pc specs
Core i3 2nd Gen 3.75 ghz
Acer H61h2 ad motherboard
2gb of ram and 2gb of video card
600w psu
Thanks in advance and sorry for my english
Hi! Thanks for the reply.
I remove the mobo outside the case and place in a cardboard. But still did not work. I also reseat the cpu but no change.
Also when i removed my mobo i discover that it only have 4 screws and 2 of then have only standoffs. Is that can affact on my mobo and cause of that issue??
Thanks
Thank you again! I just worried if my CPU can be also affected of that issue? Do i have to replace also my CPU 🙁? or replace just the motherboard? Thank you and sorry for my noob question.
Sir! Now Im Confuse. I just try to turn on my PC, on my first try it turn On, but no Beep. but still Fan is still spinning. I turn it off manually by pressing the power Button. And turn it on again. Now it turns on with beep. and Runs Normally im using it right now.
Now im confuse because I dont change anything in this PC.
So Sir, is my Motherboard are still good to use? it is not the problem?
I will start to troubleshoot again my PC to see what is the real problem.
Thanks for keep replying! I really appreciate it.
Thank you Sir. I will now again troubleshoot my PC. I keep you Up to date
