PC turns on, no POST, no beeps, fans working and nothing on the monitor
RastislavB
159
So I got the PC setup and all and when I turned it on, nothing. Shut it down using the switch on the PSU and then tried turning it on and it booted into XP. Then it froze and I shut it down again with the PSU switch and now it won't display anything on the monitor when I turn it on. The monitor is good, it worked when I tried ot on my laptop and the cable is good too. I had an internal speaker already installed on the motherboard so I tried booting with no RAM (usually has 1 stick of 1 GB) and there were no beeps, removed the graphics card and still no beeps. I removed the HDD, Optical drive, Network card and front panel card reader and still no beeps. Used my multimeter to check the voltages on the PSU and I got these results :
3.3 V wire showed 3.2 V
5 V wire showed 5.2 V
12 V wire showed 12.6 to 13 V.
These results were measure with the PSU spinning the HDD so it had load. I was using an analog multimeter and I know it works correctly because I checked some 1.5 V and 9 V batteries with it and another multimeter and the results were the same. When I had the graphics card installed I could feel that the GPU was working because the heatsink was warm to the touch (has no fan, passive cooling). With everything plugged in the CPU fan works, HDD spins, I can open and close the optical drive, the GPU is working, on the front the power light works and my motherboard also ha a power light that lights up too. Could you please help me in diagnosing the problem?
I checked the capacitors on the motherboard, the PSU and the graphics and they have nothing unusual on them, they aren't leaking and they aren't swollen. Thanks for the advice tho, I wouldn't even think of checking them.
Yeah, I was thinking it was the PSU because it's the first thing to go. I'm gonna buy some decent PSU later and hopefully remember to put if it was the solution here so others can see if they find themselves in this situation. Thank you.
Just a little update, the PC now turns on but the CPU temp slowly rises and eventually it shuts down. Going to swap the thermal paste with some new paste and install an additional fan since it has no fanse exept the one on the back of the PSU and the one that's one the heatsink. It was plugged in for a few hours before I turned it on so it might have been that the little battery on the motherboard was empty so it is recharged now.
Updating again, the overheat issue was the heatsink fan not working because there was so much dust. Cleaned the dust and now it's idling at around 30 degrees Celsius and my only fans are the PSU exhaust and the heatsink fan.
