PC turns on, will not display ANYTHING on Monitor.
IcedKnowledge
13
Hello again everyone, I've recently built my custom build and lately I haven't gotten it to work.
Here are the specs:
AMD FX 6300
Cooler Master Hyper TX3
MSI R7 370 4 GB
Gigabyte GA-970a-UD3P Rev 2.0
G. Skill Ripjaws X 16gb
Thermaltake Versa H22 case
EVGA SuperNova 750w PSU.
SanDisk SSD (120gb)
Seagate Barracuda Hybrid Hard Drive 1TB.
I have already removed the CMOs, that hasn't worked.
I've already RMA'd my graphics card.
I tried a different VGA plug. (Internal VGA plug.)
remove everything except CPU, MB and PSU - and use the internal graphics output. Test. If it provides a display - move forward. If not - one of the three is causing the issue. (note if the fan and lights are going - it's likely the CPU or MB.)
Add a stick of memory in the correct slot - test. (repeat for all memory) this identifies any issues with the memory.
Continue to add another component and test to isolate the issue.
Alternately - if the first step does not succeed - your MB or CPU is in question - then find a friend with compatible parts and test in their system.
Good luck.
