Question PC underperforming need help !
Aug 8, 2020
7
Hey Guys,
I have a pc which I built myself. Now I built my PC off many benchmarking videos on youtube. My specs are as shown:
Ryzen 3 3200g
1650 Super
2x 8gb ram @3000mhz
Simple case
5 coolermaster RGB fans
400w Striderstone PSU
Now in specific I play fortnite and multiple benchmarking videos with the exact same specs are getting over 120 fps on low settings. I can't even get over 100 fps in the game. I have installed all the drivers and the temps are down low. The only problem is is that my cpu is running at 100% usage.
Any helps would be greatly appreciated Thanks :)
Aug 8, 2020
7
What type of brand and model of the memory you using?
With that Power supply? you must be joking!
Cheap setup no good, Good Setup not cheap!
Memory as follows: GeIL 16GB Kit (2x8GB) DDR4 SUPER LUCE RGB SYNC C16 3000MHz
And the PSU is not that bad the 12v+ handles the 3200g and 1650 super.
and it's a budget setup
Jun 10, 2020
26
lol you are crazy to use that build with that psu, go and check later if it is not damaged, bad psu with not enough power to handle the build can damage your components
