PC Upgrade Help!
I'm sorry, I don't know the prices in India. Can you suggest a few graphics cards that you can afford?
Woody
Woody1999
Admirable
With $100, you will not be able to get that computer to run Far Cry 4! You're looking at at least a modern i3 with a mid-range graphics card to run that even at low settings.
Need for Speed: Rivals has a minimum requirement of an Athlon II X2 and an HD 3850, which is about equal to your current setup. If you want to run it at medium settings, 60FPS, you should get a new graphics card.
I recommend the R7 260X, it's the best card for that money.
Woody
pradyumna rahul
8
Is there a alternative to the Radeon 260X
As it is pretty expensive in India
Woody1999
Admirable
The GTX 750Ti performs similarly, however it is often more expensive than the 260X.
Woody
pradyumna rahul
8
Something just under $100
pradyumna rahul
8
It does not have to from india but the price must be lower than or equal to $100
Woody1999
Admirable
I wouldn't bother buying just yet. The R7 250 is just about all you can afford, and the performance increase of that over your current card is negligible. I suggest that you save until you can spend 10K on an R7 260X.
Woody
WildCard999
Sadly your options are quite limited for that amount of money. Your best bet is to save up and when the AMD 3XX series comes out the 2XX series should (hopefully) drop in price. Release date should be soon.
