I have been using this PC for a while now more than 5 months but I am now deciding to upgrade it BUT I need help.
Here is a link of the PC I have: http://
My Specifications are:
Operating System: Windows 10 ( Upgraded from 8.1)
Processor and Speed: Core I5 - 4460 | 3.2 Gigahertz
RAM: 8GB DDR3
Graphics Card: Nvidia GT 720
Video Memory: 2000 MB
Hard Drive Type: SATA
Hard Drive Capacity: 1000 GB
Expansion Slots: 1 PCI Express x1, 1 PCI Express x16, 1 mini PCI Express
* I'm Not sure what Motherboard I have, The PSU Is some brand I don't remember but not one of the top brands that's for sure, This is something I plan on replacing but need help with.
** Also I provided a link to the PC so that you guys can see how the PC looks and consider the space and airflow.
I play games like CS:GO and Dota 2 with playable FPS I don't do 1080p because i get lower FPS especially when a lot of effects are happening, but I play on lower resolutions because I feel better with it, I have other games like Far Cry 3 I cant play on high because I get low FPS around the 20 so this isn't a 1080p Build
I would like to play games like MGS V TPP and other games on at least 1080 doesn't have to be max settings and I don't mind having AA off I'm ok with 720p on High but preferably 1080p.
For my Budget I am willing to spend $500, If I need to I can spend 100-200 more but $500 is my budget. I think that my upgrade would be GPU and PSU but I would like opinions on what I should get because I don't know what PSU to get based on what GPU
Thanks!
RAM: 8GB DDR3
Thanks!
