Pc upgrade help
bobimo
13
Im upgrading a rig that I have... and Im a little confused on what video card to throw in there. Just a mid-ranged card Im going to buy ram and throw it in there as well about 4gb or maybe 6gb of ram. Any ideas on a video card I can put in there?
Here is the pc that im upgrading
http://www.amazon.com/Dell-Dimension-Athlon-Dual-Core-Windows/dp/B000VEOYJ8
With probably this ram
http://www.bestbuy.com/site/Memory+Master+-+2-Pack+2GB+PC2-6400+DDR2+DIMM+Memory+Kit/9360069.p?id=1218090910478&skuId=9360069
or 2 2gb sticks of pny ddr3
or this ram which i think is a lot of a better deal
http://www.newegg.com/Product/Product.aspx?Item=N82E16820178333
I highly recommend starting with a fresh build. Meaning new case, motherboard, power supply, etc. The processor is old and will bottleneck your new video card, so you'll need a new processor and a new motherboard to go with it. You're going to need a new power supply anyway.
