Pc upgrade Please help
TwinikleTom
8
Hello I am thinking of upgrading my graphics card and power supply I have a very old pc.
This is the graphic card I am planning to get
http://www.ebuyer.com/584658-sapphire-r7-260x-oc-2gb-gddr5-dvi-hdmi-displayport-pci-e-graphics-card-11222-06-20g
And this is the power supply i'm going to get: http://www.ebuyer.com/429985-corsair-cxm-600w-semi-modular-80-bronze-power-supply-cp-9020060-uk
I am wondering if its all good and if there is any problems the graphic card says it needs a 2x75 pin and a 1x75 pin (If you scroll down in the link I gave you you will see its requirements ) Will the power supply and graphic card be suitable for each other.
Im sorry but I have another question this is my whole computer specs
Processor: Pentium(R) Dual-core CPU E5300 2.60GHZ (I know its extremely old)
3GB RAM
32bit os
Graphics card: The one I mentioned yesterday
My question is would I run the game ARMA3 with a decent fps like 30 with these specs? I know my CPU Is very very old but would it still be alright?
you can run it but you wont achieve great FPS even i dont on my best set up's, reinstall your windows in 64bit instead of 32 bit
