[SOLVED] Pc Upgrade problem
mihnea20053
17
Ok. So i have and i5-6600k overclocked to 4.0 ghz and a gtx 960 2gb with 8gb ram and my pc needs and upgrade but I don't know what to upgrade, the cpu or the gpu?
You have to upgrade your GPU and RAM and then CPU.
Because your i5 6600k is still powerful enough to let you play all games till 2019.
For GPU. You should wait until AMD release it's Navi GPUs.
Otherwise RTX 2060 is good for you.
For RAM get minimum 16GB RAM for modern titles.
