pc water cooling
CaptainFluffyBear
62
I recently build a pc, but the airflow is so bad, it runs cooler with the side panel off... So I want to buy a water cooler for my CPU. (FX6300 AM3+ socket) I was thinking about the i55 from corsair but will it fit in my case? (SPEC-01 from Corsair)
Thanks and sorry for my bad English.
You mount it on top of your CPU and you usually mount the radiator as exhaust in the back. IMO closed loop coolers are easier to install then air.
You don't change any fluid, you slap it on and you're good to go, there's no maintance.
Just look up a couple videos on youtube on how to mount a closed loop cooler, it's easy.
Also, it comes with thermal paste but you should always buy it seperately that way you get the good kind that will knock off a couple degrees.
