PC water loop flow meter
derpmaster
96
Alright I've got a bitsopower flow meter but its to big and I can't find a place to put it so I need a new one that's compact. Suggestions
Alphacool one not what i looking for and the koolance is pricey do to fact you need the front mounted meter too. i like its style tho and with compact compression fitting its would work. Any more suggestions?
Why do you feel you need a flow meter?
It adds flow restriction to the loop and is really not necessary, it is more of a novelty than a necessity.
I've never ever run a flow meter and I'm running dual loops, most water cooling veterans don't run one.
If your water pump dies you'll know it, your CPU or GPUs will simply shut down, replace the bad water pump and you're back in business.
When you add unnecessary flow restriction to your pump load, you shorten the pump life.
Makes sense. I was just told by the guy who introduced me to water cooling that a flow meter was a good idea in case the pump died. I guess i wont use one if its not necessary, plus the system looks way better without it.
Im using a XSPC kit and the LED's that came with it are broken so im waiting to get new ones so i can see inside the reservoir. One more question im considering includeing my GPU into the loop radeon 7950. but its a sapphire duel fan, its it even worth doing for the some 130$ it cost to convert it.
What parts you want to cool with your water loop are up to you and you certainly can cool the video card with your loop. I have been cooling my video cards along with the cpu, motherboard and ram for some time now and do see value in including the video card if you do a lot of gaming.
Gaming will heat up the video card quite a bit and to have water cooling will eliminate that increased fan speed when the card is stressed by increased game action. S if you can afford it you should but as with anything else it's your money so if you want to then go for it.
I can afford it im just tryin to get my head around how the system will have to run now. as of this moment I have a rez/pump > radiator > cpu block > drain > rez/pump. where would i include the gpu block.
Well if i do include the gpu ill probably be getting a 14o mm radiator to put in after the cpu and then route down to the gpu but i dont know where to put my drain if i inlude the gpu. i dont like running it directly off a waterblock either its ugly.
Video cards love watercooling...you can easily see 20-40C GPU load temp drops with a properly configured loop.
Agree with others; no need for a flow meter...adds restriction and isn't going to provide much value as you'd have to maintain constant watch on it. Better solution is to use software temp monitoring with a shutdown script (that most include) along with a trigger threshold. Sounds complicated, but it's pretty simple with most software solutions (and they are usually free). Check out SpeedFan, RealTemp and CoreTemp for starters.
I understand what parts i need thats not the problem im just trying to think of how i want to order everything in the system so i looks nice and has a good flow rate. im going to get the EG 795o full coverage waterblock and the backplate for the giggles. Im running the older model of XSPC kit systems with a 24omm radiator. with 1/2, 5/8 tubing. with compression fittings
Order of components in the loop has no impact to performance beyond a few degree's, wouldn't worry about that.
Look up other water-cooled rigs using your case, visualize where all the components and their ports are in your head, draw it out. That is how you will figure out what tubing runs you need to do.
Ite, well any advice on brands of blocks for the gpu that look nice. So far all ive seen is a EG set thats is full coverage. Oh and will the extra block cause any pressure drops or will it be about the same?
One of the things that I found with water blocks for the video card is that it's hard to really see the block once it's installed because in the case it's facing down and all you see is the edge of the block. So what you want to do is get one that has some better connection parts that will dress up the loop connections.
As for pressure drops try to keep the length of the loop as short as possible and that will keep the pressure high even if you add a video card block. It's also a good idea to not have too many 90 degree fittings.
I do like that First one it was one of the ones i was looking at but i couldnt think of how to connect it since the ports would be facing down. and since i dont have 2 GPU at this time (plan on getting another when price drops) how would i do it besides 2 90degree fittings?
