Hi All,
I recently turned on my PC and received no output on the HDMI out (there is no VGA out on the integrated GPU). All that happened was a regular 'clicking' from the motherboard speaker, a faint click (not a beep) roughly once every 3 seconds. The system had previously been working fine for around 3 years - I've made no changes to any hardware.
To try to diagnose the issue I unplugged all non essentials, leaving only the following plugged into the motherboard:-
I reset the CMOS.
I powered on with a single RAM card in slot 1
The CPU Fan spins, the speaker clicks every 3 secs, no beep, no output to TV
I then powered off and removed all RAM. I powered on again and this time with no RAM sticks the motherboard sounded continuous rapid beeps (not clicks), it also restarted itself after I turned the power off (continuous rapid beeps again)
I next tried to use the other RAM card, in the same slot (slot 1)
This time the system powers on for a few seconds (CPU fan spins) then powers off. It then powers on again without any intervention from myself (CPU fan spins), single beep, no video output. The system is now 'easier' to power off, in that there is no need to press and hold the power button for a few seconds - one touch is enough
I followed the exact same process again, this time the system powers on (CPU fan spins), emits a single beep and there's no output (so this time it doesn't turn off then restart).
If I plug in the two system fans, both spin.
I've also tried seating a single RAM stick into each of the four slots, no luck.
Any help to further diagnose the issue would be much appreciated! I have reviewed the guild at http://www.tomshardware.co.uk/forum/261145-31-perform-steps-posting-post-boot-video-problems but seeing as this isn't a new build and has been working fine for years, a lot wasn't relevant.
Many Thanks in advance
Steve
System:-
PSU (both 12v Power and ATX)
55 inch TV (through HDMI out)
1 x 4Gb Ram (of the 2 that I previously had)
CPU Fan
Motherboard speaker
Power switch
I reset the CMOS.
Steve
System:-
Motherboard: Gigabyte Z97P-D3
PSU: Corsair VS550
Processor: Intel i5 4690K (stock heatsink)
Hard Drive (Boot): Samsung 850 EVO 120Gb
Two additional hard drives and 1 x DVD drive
RAM: Kingston Technology ValueRam 8GB DDR3 1600MHz Single Rank x8 DIMM Memory Kit - (2x4GB)
GPU: None, use onboard GPU
