PC will not cold POST
HuntTheShunt
32
Hi,
The PC will post if it has been powered on for a time by pressing the reset button.
What is the fault when a PC POST from cold?
I have test swapped the power supply.
Removed and replaced the 2 ram chips individually in different order an just as single units.
CMOS voltage is within tolerance at 2.75 volts and has been swapped out for another with a similar voltage 2.8v.
No post beeps are heard when PC refuses to boot.
Any ideas people?
Thanks.
Motherboard ASRock K7VM2
2*DDR Dimm
Athlon Duron 2400+
Socket A(462)
OS XP SP3 (but not really relevant to this problem)
Thanks for the info.
Time to dump it.
