PC Will Not Detect Samsung Monitor
ScottMescudder
Commendable
Feb 1, 2017
48
Hello,
I have recently bought a Samsung S27A350H Monitor. There is a VGA and HDMI port on the back. The monitor works and is responsive with Xbox One and Chromecast. When I use HDMI from my R9 480 GPU to the Samsung monitor I get no signal nor is it seen by device manager or display settings. I just tried using the DVI port from my GPU with an HDMI adapter to run to the monitor. Again no signal nor is it detected. The cables all work fine and all ports on the GPU work with other monitors.
What I've tried:
1. Change cables and adapters
2. Installed monitor specific driver
3. Updated all R9 480 drivers
Specs:
AMD 8350 8 Core 4.0GHz
AMD R9 480 4GB GPU
16GB Hyper X Fury DDR3 1600
(If it helps)
The monitor will auto detect sources whenever I use the auto detect button but it will not let me adjust the menu settings other than PC vs AV modes.
Just tried this and the PC still does not detect and no hardware changes in device manager are seen. My monitors info screen displays 1920x1080p resolution at 60hz. My PC display settings are 1920x1080 at 60Hz. Same goes for my Radeon graphics card settings.
