So i have a dilemma need some help a PC problem if anyone here could help. Need some Geeky PC savvys to help . Note: Add me if you can help me figure out the problem.
My PC wont POST at all, turn it on, im stuck at a blank screen. Solutions ive done so far that has not helped.
CMOS RESET, Switched ram around to different slots/different ram, Changed the PSU, unhooked everything and pressed the power switch, Reseated my CPU/GPU, Tested my monitor on a different pc it worked, Changed my CPU/GPU to something different, changed my MOBO, changed my HDD etc. My Sabertooth doesnt have any onboard Videocard, so i cant test that, Switched to my old moba used the onboard video, nothing still. Tried VGA/HDMI/DVI nothing happened still. CMOSed both mobos, tried different setups nothing has worked ... Felt like i built a new PC from old parts and nothing worked. Its plugged in directly to the outlet, so no powerstrip is being used. Could it be that my OUTLET is not putting the power out that is needed? Everything is powered on, ive used 2 different PSU's and 3 different GPU's and 2 different CPUs and 3 sets of different Ram. TBH i feel as if i encountered this problem before and need to swithc to a different outlet, But im not totally sure.
