Question Pc will not show output on monitor and ez debut cpu is on.
Dec 2, 2022
5
Hello, I am building a computer and I finished everything and the computer is not working. The cpu debug light is on and it will not go off, there is no output to either of my monitors, also the power button does not work when I click it for turning it off so I have to hold it for 4 seconds also sometimes there is a dim flash in the dram ez debug light also, when I turn on the power supply and click the power on button on the case there’s about a 5 second delay.
This is what I have tried so far to fix my pc:
Resseting cmos
Bios flashback
Using different cables and monitors
Using different sticks of ram
And the light is still on with no output.
Specs:
Msi B550-A pro (cec)
Rtx 3060ti
Ryzen 5 3500
8x2gb ram vengeance lpx 3200mhz
650w rose well hive bronze rated power supply
How old is the PSU in your build? As for your motherboard, try reseating the memory on the board. While doing so, make sure that they are seated fully/properly into the slot.
As for your BIOS, use this BIOS;
https://download.msi.com/bos_exe/mb/7C56vH0.zip
to flash the BIOS on your motherboard, to at least get the platform up and running. With this step, remove the RTX3060Ti and see if you're able to POST and get display output from the APU.
When I try running the pc without a graphics card in it, the ez debug switched to vram and beeps 3 times.
I’m going to download that bios but I meant to put ryzen 3500 in the spec list not 5600g will that bios still work?
That bios version did not work.
