jojesa Glorious Dec 6, 2006 7,180 551 47,440 Jul 10, 2018 #2 lunastreet30ri : how to check a motherboard Is this a new build? Could you post your system components (with model #s). Upvote 0 Downvote
L lunastreet30ri Jul 10, 2018 2 0 10 Jul 12, 2018 #3 jojesa : lunastreet30ri : how to check a motherboard Is this a new build? Could you post your system components (with model #s). HP PAVILION 6 YEARS OLD. I've UPGRADED VIDEO CARD, RAM, ADDED A SECOND IN CASE DRIVE. MODLE NUM. A6200N M.B. NETTLE 2 GL8E. BOARD NUM. MCP61PM-HM HOPE THAT IS SUFFICIENT? THANK YOU Upvote 0 Downvote
jojesa Glorious Dec 6, 2006 7,180 551 47,440 Jul 12, 2018 #4 lunastreet30ri : HP PAVILION 6 YEARS OLD. I've UPGRADED VIDEO CARD, RAM, ADDED A SECOND IN CASE DRIVE. MODLE NUM. A6200N M.B. NETTLE 2 GL8E. BOARD NUM. MCP61PM-HM HOPE THAT IS SUFFICIENT? THANK YOU Which video card (GPU) did you get? Could you elaborate about the issue you are having? Did you upgrade the power supply unit (PSU)? Upvote 0 Downvote
