Ive had this issue twice when turning on my pc it will run for 20 seconds then turn off. I turn it back on and it turns off after 10 secs. The only way to get my pc to work again is restart the bios by hitting the cmos button on the back of my pc, After I do that my pc turns on and everything is fine. I even checked my event viewer and nothing was wrong. It was good for a month until it did it again today.
Bios updated, chipset driver updated, and amd gpu drivers updated.
X760E taichi
7950x3d
7900xtx
1000 evga psu
32 gb ram g skill.
I did update to the 1.29 beta on asrock x670e.
I do have my ram expo to 6000mhz which is the factory overclock settings. I also did a memtest and came back normal. I also like to state that it won't even get to windows so my screen stays black and then turns off after 20 seconds or so. I can't even access bios unless i do a cmos reset.
X760E taichi
7950x3d
7900xtx
1000 evga psu
32 gb ram g skill.
