S senna99 Honorable Jun 6, 2012 27 0 10,530 Jun 6, 2012 #1 Can I power my pc with xbox 360 power supply 205w
WR2 Polypheme Nov 18, 2005 27,923 6 64,715 Jun 6, 2012 #2 Have you looked at the power leads for the Xbox 360 PSU and compared it with the power input connectors of your PC?
geekapproved Splendid Dec 10, 2010 8,766 0 31,460 Jun 6, 2012 #4 In theory if your pc doesn't draw more than 175w or so, then of course you could, a xbox is basically a pc. However that doesn't mean it's going to hook up to a ATX motherboard.
WR2 Polypheme Nov 18, 2005 27,923 6 64,715 Jun 6, 2012 #5 How are you going to get power to your PC parts?
WR2 Polypheme Nov 18, 2005 27,923 6 64,715 Jun 6, 2012 #11 You'll need PSU connectors like these to get power to your PC parts.
S senna99 Honorable Jun 6, 2012 27 0 10,530 Jun 6, 2012 #12 ok I have it all, I thought that I connect wires directly only missing 3.3 v
WR2 Polypheme Nov 18, 2005 27,923 6 64,715 Jun 6, 2012 #15 How do you go from your XBox 360 power connector To the 20/24pin ATX power connector for your motherboard? And that's just 1 of the connectors you need for your PC.
S senna99 Honorable Jun 6, 2012 27 0 10,530 Jun 6, 2012 #16 My components is:g530 intel hd6570 low profil,wd 320gb,slim dvd,mb msi socet 1155
WR2 Polypheme Nov 18, 2005 27,923 6 64,715 Jun 6, 2012 #17 Socket 1155 motherboard needs 24pin main ATX connector like in the picture above. Plus a 4 or 8 pin +12V CPU aux power connector. HDD needs SATA power connector with 5V and 3.3V. DVD needs SATA power connector with 5V and 3.3V.
S senna99 Honorable Jun 6, 2012 27 0 10,530 Jun 6, 2012 #18 I understand what you say, with 12v'll divorce at each point on pc and so for everything else
WR2 Polypheme Nov 18, 2005 27,923 6 64,715 Jun 6, 2012 #19 I can't see how you can jury rig your Xbox 360 to power your PC. Looks like you need a Plan B. A PC type PSU.
WR2 Polypheme Nov 18, 2005 27,923 6 64,715 Jun 6, 2012 #20 senna99 : I understand what you say, with 12v'll divorce at each point on pc and so for everything else How are you going to step down +12V to 3.3V?
WR2 Polypheme Nov 18, 2005 27,923 6 64,715 Jun 6, 2012 #24 You're also going to have to wire the ground (com = common ground) And I'm pretty sure you need 3.3V for the RAM which is stepped down to 1.5V by your motherboard.
S senna99 Honorable Jun 6, 2012 27 0 10,530 Jun 6, 2012 #25 WR2 : How are you going to step down +12V to 3.3V? with invertor
