pc without vga card
That helps, but the HDD, PSU, and Case are likely to total over 1100 LE
What GPU are you planning to run (it will affect the PSU choice)?
I can get this
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($229.99 @ SuperBiiz)
Motherboard: ASRock Z97 EXTREME4 ATX LGA1150 Motherboard ($125.98 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($50.89 @ OutletPC)
Case: Cooler Master K280 USB3.0 ATX Mid Tower Case
Power Supply: XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply
Total: $406.86
Generated by PCPartPicker 2015-07-03 13:57 EDT-0400
For 4345 L.E., but you will need a CPU cooler as well if you plan to overclock, and the 450W PSU will limit your GPU power to about a GTX 970.
Then that's fine. The 450W PSU is good.
The local case will be the CoolerMaster 282K with USB 3.0 ports on the front panel I would use every part, except the case, myself if I were to build a computer, so there are no corners cut or sub-standard bits included.
There may be some slightly cheaper motherboards, but I would not want anything with weaker VRM or power phases if I were serious about overclocking. If there is another motherboard you would rather have, ask.
