The graphics cards fan and lights are on so it works but when I boot it doesn’t display? This pc has run perfectly before. Any ideas or need more detail?
Please post your entire system spec including PSU make and model.
So you press the power button, all fans and lights come on, but no display? Is this no signal, or a signal but a black screen?
CPU: fx6300
Gpu: thx 1060
Psu: evga 500w 80+ https://www.evga.com/products/product.aspx?pn=100-W1-0500-KR
CPU fan is stock and is some Chinese junk but it works fine. Also I meant all the lights and fans turn on properly but there is no signal when turned on
How long have you had the PSU?
It is one of EVGA's low quality/budget PSUs.
Did anything change/happen when the problem occured? Have you recently changed anything?
Were you running any overclock at all?
Only thing I did was clean out dust and stuff but I put everything in it’s correct spot and plugged in properly. The psu shouldn’t be bad as it was working a few days ago before this happened. I’ve had it for around a year so it should be good. Also no overclock or anything was running which I think would cause this no display issue. Thank you
