PC won’t display on TV
tylerd308
48
I’m pretty new when it comes to computers and I built my first build yesterday and it seems like everything is working. But I plugged in an hdmi cable to my pc and then into a TV I have and it doesn’t show anything. Should it be showing me something on the TV or do I need a monitor
I have one display which is a tv I plug my PS4 into usually. And the parts I have are:
EVGA GQ 650w psu
Rx 560 gpu
Ryzen 5 1600 cpu
Gskill fortis ram 2x8gb
B350 tomahawk plus mobo
1 tb hdd
250 gb ssd
Yes. Connect to a monitor to make sure you're getting a signal at all. Otherwise I'd be checking the graphics card. If you do, then shut down and connect the TV via a second cable to the graphics card. See if you're still getting an image on the monitor. If so, try changing the resolution/refresh rate of the TV in the AMD Control Center (Crimson?)
-Wolf sends
Got it working on my tv. I had the same issue with my PS4 when I first got it I just have to turn on my PC first then the TV. Of course I still plan on getting a monitor
