[SOLVED] Pc won’t power up
Dec 24, 2018
I’ve sent back my Power supply, motherboard and case and pc still won’t power up I have no idea what I’m doing wrong but nothing is working. Any ideas of what I could do?
Try to use other GPU, also check the CPU to see any bent pin(s) or not. And you are better to buy the better PSU for your rtx2070.
I’ve replaced both, I’m going to try another case I have spair, and see if that fixes the problem as the Front panel might be the problem
