Pc won’t show on moniter using both display outputs
Jan 2, 2019
I have a rog strip b450 f gaming mother board and everything is running but my monitor says there is no signal from the pc. I have tried the display port and hdmi but both won’t work.
The Ryzen cpus do not have integrated gpu, only the A series APU's/2200G/2400G do, which are also used on those motherboards. With a Ryzen cpu, you need a dedicated gpu for video output, you'd use gpu outputs not the motherboard video output.
Thank you
I was told that I wouldn’t need a dedicated graphics card to run my PC
