Hello I recently built a pc myself the specs are:
PSU AZZA 550W
GPU GTX 750ti
CPU RYZEN 2600 6 core
MOBO PRIME B450M-A
CPU FAN COOLER MASTER
ddr4 16GB 3200
My custom build worked fine for 2 weeks then just randomly it shut off mid game I thought maybe it was over heating, so I applied thermal paste that didn’t make it work, it was working it would turn on for 1-60 seconds and power off now it won’t power on for over a second I tried a older psu to see if that was the problem and that didn’t fix it either could it be the gpu? It’s kind of old I also tried taking it apart re wiring and nothing has seemed to fix it.(I don’t have on board gpu so I wouldn’t know) any solutions? Or ideas on what would be causing it to not turn on?
PSU AZZA 550W
GPU GTX 750ti
MOBO PRIME B450M-A
ddr4 16GB 3200
