PC won't boot. Motherboard lights up and fans spin.
Huzefa Patheria
6
Hey guy
I had a BSOD due to graphic card driver error. The Pc was automatically rebooting but I switched it off, removed the power cable and did a cmos reset. Now when I turned it on, there is no display. The CPU fan is spinning and the motherboard strip led is lighting up. There is also slight vibration in the hdd but the front panel led's don't light up. I have gone through many forums and tried almost every thing but to no avail. There seems to be power to the mobo as the design lights come on. I even removed the processor to check for some burnout damage but it all looked clean.
My system configuration is :
Mobo: MSI H97 GAMING 3
Processor: INTEL CORE I7 4790
GPU: ZOTAC NVIDIA GTX 1070
Powersupply: THERMALTAKE 630W
Any help would be appreciated.
Yup. I removed everything and left just the ram and plugged into the motherboard hdmi slot. Still nothing. I doubt Graphic card is the problem as I have two and tried both but nothing. Don't know why front panel led's don't light up.
