I recently replaced my old GPU with a radeon RX 580. I had no issue installing it and had it working. I did have to replace my power buttons because a wire had become disconnected. I was running a game when and left the room i come back to an off pc and couldnt power up because the button. I don't know why it powered off unless it was the wire to the button disconnecting. I had to remove the gpu to plug up my new power button and led. I reseated the GPU after making sure the button worked. I tried to power on but it barely lit up and the fan twitched. When I power on without the GPU wired in it it boots fine. When I power down and plug the GPU back in it not only won't power on but when I disconnect it it won't power on either. I have to replug the actual psu power cord to get it to even turn back on. I think its my PSU, that its trying to draw to much power but I am not sure. If it's the GPU its still under warranty.
Specs
Windows 10
Intel i7 p6700
Radeon RX 580 8gb gddr5
8gb ddr4 memory
500w PSU
Acer model A73-714A-UR11
Update
It's the GPU tested it on another mobo, no power on, must be the gpu
Specs
Windows 10
Intel i7 p6700
8gb ddr4 memory
500w PSU
Update
