My pc specs are:
Ryzen 3600x
Biostar B450
Crucial ddr4 3200 mhz 8gb x2 ram
GTX 1070
My pc worked perfectly then I installed a pcie wifi card and while it worked I got a "Driver_IRQL_Not_Less_or_Equal" BSOD. I ignored it and restarted the PC same used it for a bit got another BSOD this time the pc wouldnt POST. I removed the wifi card, tried removing cmos battery, trying ram sticks in different slots, reputting components, disconnecting peripherals but it won't work.
After countless trying i left it some hours without the power cord then when I booted it It worked, all my ram cpu and gpu was detected in the BIOS so I shut it down to connect my keyboard and mouse but now it won't POST again. I assumed the wifi card was somehow faulty or another fried motherboard so I got a new one, the Asus Prime B450M-A II but the pc still wont POST.
The fact that the ram and cpu were detected before and that the gpu worked as well makes no sense to me.
I tried using another PSU but it still won't POST. Which part went faulty?
What is the problem, what components can a wifi card kill and if it really killed them why did it decide to post at one point randomly ?
Ryzen 3600x
Biostar B450
GTX 1070
