Hello!
I purchased a system including an MSI B500M Pro-VDH WiFi motherboard and a Ryzen HD 8490 GPU to test the graphics (this computer's purpose is primarily CPU).
However, it will not display in a testbench configuration. RGB on the CPU cooler and RAM are on, indicating that they're active, and the GPU fan is occasionally spinning, which leads me to wonder whether the GPU and motherboard are compatible, or if there's anything else obvious I'm missing.
Full spec list is:
Full spec list is:
- CPU: Ryzen 9 5900X
- RAM: 128gb DDR4
- GPU: Ryzen HD 8490
- Motherboard: B500M Pro-VDH WiFi
