[SOLVED] Pc won't Post/boot problem
Swinginking
130
Hi,
Have had a water cooking leak, just a a small splash, i noticed it after my CPU started running hot, so I quickly turned everything off, disconnected everything.
Have now rebuilt the computer entirely with a stock fan, cleaned everything too. But now the pc won't boot. The fans spin for a second and off.
If I take the CPU out, and boot it keeps running but no video.
I am running the Z97 with 4690K
What could be the problem? Perhaps I have had bad wiring but where could that be?
Thanks
Does your board have a Q code display or do you have a system speaker attached to the motherboard? If so, are you getting any specific codes or beeps? If you don't have a system speaker attached, it's probably a good idea to get one. In most regions they can be easily obtained online or through most repair shops for only a few dollars.
For now though, I'd check and double check everything mentioned at the following link.
**Click here for help troubleshooting hardware and No-POST issues
