PC won't post (please help)
Larry_The_Great
41
Hey forum members,
So my friend's computer recently wouldn't post and we're not sure what's wrong. I have checked the psu is working by using the paperclip method with the 24pin connector and sure enough the fan started to spin. As for the motherboard I have pulled out all of the cables and only have the essentials: 24pin, Cpu 8pin, 1 stick of ram (I've tried it in every slot), cpu fan 4pin, gpu with power cables connected and it still doesn't boot. My friend said he checked the socket for bent pins and it didn't look like there was any but I personally haven't checked myself. When the power button is pressed on the motherboard the red error LED flashes and the fans start and then it reboots. Here is a video of the process:
http://www.mediafire.com/watch/ncgfepdlj47a5bi/video-1425117961.mp4.mp4
If anyone knows what could possibly be going wrong then please let us know we greatly appreciate it. The PC was working fine a few days ago I believe he took it apart to put some LEDs or something and now it doesn't boot.
Thanks
Try the memory in another slot.
On my particular mobo with 4 slots it says to populate slot 2 first (2nd one over from the cpu). I can't tell which you are using. But slot 4 should also work. hmm:??:
I've already tried it in each of the slots and it still doesn't boot unfortunately
