I have recently built my first PC. I've had it for about two weeks and moved from upstairs. Upon powering on the system it ran normally for 3-5 seconds then turned off. Nothing happens at all unless i unplug the psu power cable and turn the psu switch off and on then plug it back in which gives me a small amount of case, cpu, and psu fan spin, otherwise if i remove the cpu and gpu power cables then the pc will turn on with all fans running at full
