Question PC won't power up unless I turn off/on the power switch on the PSU ?
Ruriko
14
I have a gaming pc that is 5months old. I'm having trouble getting my PC to turn on. When I press the power button it will not boot up but I can see RGB lights are on and keyboard lights. Only when I flip off the power supply for a few minutes and turn it back on then press the power button the PC will finally boot up. Running the PC is fine but it does randomly turn off once every 2-3 days. If I tried to reboot the PC it will turn off and back on but once it displays the MSI logo it will turn off so I have to cycle the PSU switch.
Please note I'm a newbie so I don't have much knowledge on computer parts. Is there any fix for this problem ?
Specs:
  • Case: Deepcool CK560 Mid-Tower - Black [DPC-CK560-ATX-BLK]
  • CPU: AMD Ryzen 5 7600 | 6 Cores | 3.8 GHz (Max 5.1 GHz) [AMD-R5-7600]
  • MOTHERBOARD: MSI PRO B650-P WI-FI ATX - DDR5 [MSI-PRO-B650P-ATX-WIFI]
  • RAM: ADATA XPG SPECTRIX RGB 32GB (2x16GB) 6000MHz DDR5 - Black [ADTA-XPG-LANCER-2X16GB-6000M]
  • GPU: MSI NVIDIA GeForce RTX 4070 VENTUS 3X OC - 12GB [MSI-RTX4070-VENTUSOC-12GB]
  • POWER SUPPLY: InWin 850W 80 Plus Gold - Modular [INW-P85-GLD]
  • CPU COOLING SYSTEM: DeepCool AK400 Air Cooler [DPC-COOLER-AK400]
  • THERMAL COMPOUND: Stock Thermal Compound
  • Case Fans: 4x DeepCool Stock 120mm ARGB Fans
  • PRIMARY SSD: 500GB GIGABYTE AORUS M.2 Gen4 M.2 (R: 5000MBs| W: 3800MB/s) [GIG-AORUS-SSD-500GB-M2]
  • FIRST HARD DRIVE: 1TB Seagate Barracuda 7200RPM [SGT-BRCDA-HDD-1TB]
  • WI-FI & BLUETOOTH: Onboard Motherboard Wi-Fi & Bluetooth
Reactions: Order 66
