PC Won't POWER!!!
Xp_jericho
My PC won't turn on. I just got everything in my case, put all the wiring together and press the power button and nothing show
Make sure you plugged the right wire Into the CPU, I belive it takes a 4 pin wire, I was plugging in a spare 3 pin PCI. Look at your Motherboard manual and make sure you have the right wiring, I.e the power, led, reset wires.
