[SOLVED] PC won't power
Aug 10, 2019
Hi guys
Built a new computer roughly a month ago and has been working perfectly. I wanted to neaten up my cables so I did and then when I plugged it all back in it would not power on. I've checked all cables to make sure everything is in correctly. The RGB lights on my motherboard and keyboard all come on but I get no other power. fans won't turn on doesn't even try post.
Hmm, just if it worked and now doesn’t then the obvious problem would be something isn’t connected properly. Sorry I guess you have tried this but you did also check the psu end of each cable? Next would be taking out all cables and checking for a loose wire/pin in each connector.
