Question Pc wont show display signal and mouse and keyboard dont work after ride in car
Dec 23, 2022
I had to transport my pc with a car, and when i installed in my new place and turned it on, it beeped 5 times and there was no display signal and mouse and keyboard did not work, I first had this problem when i first built it, but i took it to a repair shop, and the problem was a slightly bent pin on the intel motherboard. This happened a few times after but I always managed to fix it by taking the cpu out and putting it back in, but this time it didnt work, what can i do
Update your post to include full system hardware specs and OS information.
Refer to the motherboard's User Guide/Manual and/or the manufacturer's website to learn what the 5 beeps may indicate.
Listen carefully: The beeps could be a pattern of long and short beeps.
Check for any troubleshooting LED's.
Power down, unplug, open the case.
Clean out dust and debris.
Verify by sight and feel that all connectors, cards, RAM, jumpers, and case connections are fully and firmly in place.
Hopefully, something just jostled loose during the drive.
Pull out the GPU and reseat it, and also the ram. Make sure all the cables and connections are tight and good.
provide the specs as listed above, so that we can look up with the five beeps mean
