Question PC won't shut down and USB's not registered PLEASE HELP :)
sammb7560
24
Hi everyone, I recently built a new PC and I have a few issues with it. Firstly, I am not able to turn off my PC normally and I have to hard shut down by holding the off button on the case. When I press shutdown or press the off button on the case it does the normal shutdown procedure and then the displays will turn off, however the PC remains fully running with all fans and lights still on. It will then tick over as if it's about to fully shut down and then the displays will turn back on again after it ticks over a few times. However, when the displays turn on I have no icons on the desktop and the task bar also has no icons other than the start button and the bottom right icons. So I then have to hard shut down which is not healthy for the PC. Also, when I first switched it on after building it, the PC would blue screen every time I shutdown using the start menu but it would work fine if I shut down using the PC case but recently I cannot use either to shutdown (I also don't bluescreen anymore).
The other issue has been persistent since I built the PC. Every time I plug a device in using a USB to the ports, it doesn't register that they have been plugged in unless I restart the PC. Also, if I were to unplug my external HDD it will not recognize that it has been unplugged and I am still able to access it in documents. This is the most annoying as my mic cable falls out a lot if I nudge the mic which means I have to restart my PC every time which is very annoying whilst gaming.a
I have used driver talent to update all of my drivers so it's not an issue with that. I also haven't changed any settings in the bios and windows fast boot is turned off. Please help thank you :))
