[SOLVED] PC won't start after power cut whilst running CHKDSK ?
Sep 10, 2021
Hello,
I am facing a problem while i using CHKDSK on my system. Problem started from yesterday when i was using chkdsk running on my pc and my electricity cut off. After that when i tried to start my pc it showing this error. If i press Esc its showing me this. I tried with this method which i found from google. I follow many other method still getting this error.
Tried with command promt (fixmbr/fixboot). After go throw the windows error code :0xc000000f which occurs for corrupted file, a damaged drive, or a malware or virus infection. Tried changing drive/cable, its not working. But when i press F12(Bios menu) its showing me this.
Samsung Evo 860 is my main drive which has OS install, Toshiba is my second hard drive. Tried change boot sequence still this error comes. Can anyone help me to get solution of my problem ?
My setup is:
Aorus B360 Gaming WiFi
I5-9400
1050 Ti
Apacher 8GB DDR4
Thanks
