PC won't turn on after being in sleep mode overnight? [SOLVED]
Ross_McD
16
Last night I left my PC on so that it could finish uploading a large file while I slept. In the morning the PC was in sleep mode and I could not wake it up. This has been normal, I think I needed to change some settings so the keyboard/mouse could wake it, or maybe there is something more, anyway when this happens I turn off my PC. Today however, my PC would not turn off. It would not restart either. I switch the power supply off, and then turned it back on. The PC would not power up after this. No fans, no LED lights, only usb ports have power. I had a similar issue when I first built this PC because I had plugged the front panel connectors in incorrectly. It worked for a month, no change in wiring or anything like that since. What is strange though is that the usb ports only receive power if I press the power button, but do not turn off if I press it again. Before the usb ports had power as long as the power supply was connected. Not sure if that is a clue or not, but I'm at a loss as to what to do because I can not even access the BIOS.
MB - Gigabyte BISOM - DS3H
PSU - Seasonic S12 Bronze II 520W ATX 12V
OS - Windows 10
I've disconnected everything from the motherboard and and tried to power it without the video card and one of the RAM cards, but no dice. Put everything back together the way it was before and tried using a separate outlet for my power supply. Still nothing. The Monitor has an amber light on indicating its not receiving a signal from the PC, I believe, but again all usb ports still receive power when the supply is on and the power button is pressed. Any ideas?
Thanks so much for the reply. I finally fixed the issue I was having by removing the circular battery in the Motherboard, (referred to as the CMOS?) and reinstalling it. After I had done this the PC booted Windows 10 right up, and I was able to log in. After logging in I went to Device Manager, right clicked keyboard>properties>power management and checked the ability to wake the PC. I did the same for the mouse and now when my PC sleeps I can wake it up without restarting.
If someone else is having a similar problem with the PC failing to boot I would recommend starting with the CMOS. If reinstalling after a few minutes or replacing it does not fix your problem investigate your PSU. If this is working as mine was it could be a problem...
What OS did you use?
FOR WINDOWS VISTA & 7 ONLY
Troubleshoot problems waking computer from sleep mode
Symptoms
When you use a Microsoft mouse or keyboard that is listed in the "Applies to" section, you may experience one of the following symptoms:
You may be unable to wake the computer from sleep or standby mode by using your mouse or keyboard.
After you wake your computer from standby, your pointing device may not work.
When you press the SLEEP key on a keyboard that has a Sleep key or has a key that is configured to activate Sleep, the computer does not go into Sleep mode.
Cause
This issue may occur if one or more of the following conditions are true:
You are running Windows Vista and have not updated to Service Pack 1 or a later version.
The Basic Input/output System (BIOS) system that is installed on the computer reduces power to the port to which the input device is connected.
Note You may be unable to use Bluetooth devices to resume operation from certain power management states (such as "suspend" or "hibernate"). In some low-power states, the wireless transceiver may be unable to receive information from the Bluetooth devices.
You are using a portable or notebook computer that does not allow resume by using a Bluetooth device. If you are having problems waking a laptop by using a Bluetooth device, see Method 3 first.
The Keyboard item in Control Panel is not configured to wake the computer when you press a key on the keyboard.
Your computer may have encountered a system problem.
The Sleep key on your keyboard is configured incorrectly.
Resolution
If pressing the Sleep key again does not resolve this, try each of the following methods in the order in which they are presented and determine whether the problem still exists before you try the next method. If you are using the original version of Vista and have not updated to the latest available Service Pack, updating to Service Pack 1 or latest version may resolved this problem.
For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base:
http:// A USB device may no longer work correctly after Windows Vista resumes from sleep or from hibernation.
http:// USB device is not recognized when you attach it immediately after your Windows XP-based computer resumes form standby or hibernation.
http:// A Bluetooth device may no longer work correctly when when you wake Windows Vista-based computer from sleep.
Method 1: Install the current software for your device and verify its configuration
First, download the latest version of the Microsoft IntelliType software, IntelliPoint software , or both for your keyboard, your mouse, or both. To do this visit the following Microsoft Web site:
http://
After you install this software, run it, and then verify that the correct device is selected and that the settings are as you want them to be. If your keyboard does not have a dedicated Sleep key and you want to program Sleep for an alternative key, follow these steps:
1. Open the Keyboard control panel.
In Windows Vista or Windows 7, Click
Start Button, type keyboard in the Start Search box, and then click Keyboard or Microsoft Keyboard in the Programs list.
In Windows XP and earlier versions, click Start, click Run, type Control keyboard, and then click OK.
2. On the Key Settings tab, double-click the key that you want to change to access the Reassign a Key wizard.
3. Select the Start a Program, Web page, or file option, and then click Next.
4. To enable this key to start Sleep mode, run the following command:
rundll32.exe powrprof.dll,SetSuspendState
Note In this command, there are spaces before and after powrprof.dll.
Method 2: Try alternative keys, mouse buttons, or the power button on your keyboard
To resolve this issue and resume computer operation, use one of the following methods:
Press the SLEEP keyboard shortcut.
Press a standard key on the keyboard.
Move the mouse.
Quickly press the power button on the computer.
Note If you use Bluetooth devices, the keyboard may be unable to wake the system.
Method 3: Verify that your device is allowed to wake the computer
To resolve this issue for, follow these steps:
1. Open the Keyboard control panel item, as described in Method 1.
2. Click the Hardware tab, and then click Properties.
3. Click the Change Settings button
Note This step requires Administrator access
4. Click the Power Management tab, and then verify that the Allow this device to wake the computer is enabled.
5. Click OK, and then click OK again.
Note If your computer does not support Advanced Configuration and Power Interface (ACPI), the earlier steps may not be available. In this case, you have press the power button to wake the computer. If you cannot resume computer operation by using any of these methods, you may have experienced a system problem.
For information about how your system resumes operation, see the documentation that accompanied your computer or contact the computer manufacturer. For information about Microsoft Windows Power Management settings, see Microsoft Windows Help.
Note Many laptop manufactures will not allow a Bluetooth device to wake the computer from sleep mode because of the power consumption requirements to keep the Bluetooth radio activated (Bluetooth paging can consume up to 15% of the computer’s power). Therefore there are a couple of workarounds that you can use:
If you can open the lid of your laptop, use the embedded keyboard or pointing device or an external non-Bluetooth device to wake the computer.
If you cannot open the lid (for example, because it is in a docking station) or if you have it plugged into external power (that is, you are not using the battery), you can change the Power settings in Windows to not go into Sleep mode when plugged in.
Alternatively the Microsoft Bluetooth stack or your laptop’s proprietary Bluetooth stack may allow customization to allow wake by using Bluetooth devices.
http:// How to enable waking of a Windows Vista computer using Bluetooth HIDs
Method 4: Examine the BIOS settings of your computer for power features that disable or reduce power to ports that are used for your keyboard or mouse
Because BIOS access varies by computer, to resolve this issue, see the documentation that is included with your computer. Alternatively, contact your computer manufacturer for information about how to configure the BIOS.
For more information about hardware and software vendor contact information, visit the following Microsoft Web site:
http://
More Information
The ability to recover from sleep mode by pressing a key on the keyboard or by moving the mouse on a computer that supports ACPI is dependent on the computer's motherboard. This ability is disabled in older Intel motherboards, and the only way to wake the computer from sleep mode is to press the Power button.
With most newer motherboards, you can wake the computer by pressing the Power button, by pressing a key on the keyboard, or by moving the mouse.
ACPI support is necessary to take full advantage of the power management and Plug and Play features in Windows. If you are not sure whether your computer is ACPI-compliant, please see the printed documentation for your computer or motherboard, or contact the manufacturer of your computer or motherboard.
http://
Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information.
If someone else is having a similar problem with the PC failing to boot I would recommend starting with the CMOS. If reinstalling after a few minutes or replacing it does not fix your problem investigate your PSU. If this is working as mine was it could be a problem with your MB (look into purchasing a POST card for cheap) or even worse your GPU. The sleep mode issue was a software issue, not getting it to turn on was a hardware issue. Really hope this thread helps somebody, I realize how irritating and stressful this can be.
