M miksnake Reputable Apr 15, 2015 32 0 4,530 Apr 18, 2015 #1 well as the title says the pc pc won't turn on after i hooking up hard drive if anybody can guide me in the right direction thanks
mcnumpty23 Polypheme Jul 15, 2011 15,518 0 66,960 Apr 18, 2015 #2 turned on ok before connecting hard drive? if so you either connected it wrong--though not sure how or hard drive is faulty or you bumped something loose while connecting it Upvote 0 Downvote
M miksnake Reputable Apr 15, 2015 32 0 4,530 Apr 18, 2015 #3 well i have had this problem before while connecting the optical drive and the ssd. so i guess i must have bumped some cables out Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 0 66,960 Apr 18, 2015 #4 thats the most likely of what i said--though that would mean you havent latched some cables in right as the power cables have a clip/latch on them Upvote 0 Downvote
