Question PC won't turn on after power outage ?
Aug 26, 2022
Hello,
My pc won't turn on at all after a recent power outage, there's a white-ish blinking light inside. I tried unplugging etc with no luck. If someone could help that would be great!
Attached a pic of the light in question it is blinking fast.
Thanks
Aug 28, 2022
11
I would test your pc's psu, you can do it by using a paper clip as a jumper to see if it powers up the fans. (check the fuse in the plug first) . If you google "how to test your psu" you'll get loads of guides.
