My pc was shutting off randomly while I was playing games. This happened before, but very very rarely. I built this pc 5 months ago and had no issues.
Specs:
Ryzen 5 7600
Corsair vengeance 6000mhz cl30
Gigabyte b650 eagle ax
Zotac 3060ti
750w psu corsair gold
To see if I could fix the problem, I removed my rams, my gpu, the 24 pin connector and reconnected everything, and applied new thermal paste.
After that, my pc doesn't turn on, and it stays on the DRAM led, and now it's the cpu led is on and it won't move from there.
Things I've tried:
- removing and reinstalling the cpu after removing all thermal paste to see if it booted
- tested another ram stick
- cleared the cmos
- check all the cables, disconnect them and reconnect them
If you know anything about it, please help me as I need this pc to work...
Specs:
Ryzen 5 7600
Zotac 3060ti
Things I've tried:
- cleared the cmos
