Pc wont turn on need help
Brandon_105
Commendable
Jul 26, 2016
The outlet that i plug my computer in doesn't have a cover on it. so when i was reaching to plug in my pc sparks flew. i'm assuming i touched an open wire or something. now my pc will not turn on, but the lights still come on when i plug it in.
Will the computer turn on if you plug it into another known working outlet?
If not there was probably some sort of short circuit created when you attempted the plug and and electrical current went the wrong way into your computer.
First have someone knowledgeable check the uncovered outlet, fix it, and get a cover plate on. Would normally hope that whatever happened would have just tripped the circuit breaker (if there even was one). But the lights being on indicate that there is some level of power at the outlet and that the outlet is live. And can shock again.
Second, with your computer unplugged open it up and inspect all components for damage: black or brown scorch marks, melted wires, melted components. any burning smells...
Second, with your computer unplugged open it up and inspect all components for damage: black or brown scorch marks, melted wires, melted components. any burning smells, and so forth. May be hard to find - use a good flashlight and Again if you are not comfortable doing so then get help.
See what else you can find or learn. Post accordingly.
