PC won't Turn On Please Help Me
Mar 9, 2018
21
I Buy A PC Three Months Ago Having
I3 7100 LGA 1151
Asus GTX 1050Ti
Msi H110M Vh Pro Plus.
But Today I found that PC won't Turn On so I checked My PSU with Paper clip Test Then I Found that My PSU Is Dead Then I Replace It With The New PSU But problem Remain same My PC Was Not Turnings On I check All Cable And wires are Connected
That's The Image Plz Help Me
Look, if the PC is still covered by manufacturer's or system-builder's warranty, you should contact them and let them deal with it because it's fairly evident to me that you are not at all comfortable or competent where touching/removing internal computer parts is required, so you might do even more damage if you try to fix it yourself.
If it is not covered by a warranty, then take it to a PC repair shop or get a friend to look at it who knows a thing or two about fixing computers.
But try the warranty route first.
Good luck & I hope it's fixed soon.
Sir But I Buy It Just three Month s Ago and Now, How I Check exactly that my Motherboard is dead. could I Get Replacement from MSI
Sir Are You Sure that my Motherboard is Dead
Try starting the board with only CPU and CPU cooler installed. If the CPU cooler does not start, try removing the 4 pin power cable, connecting a case fan and testing again. See if the case fan does spin. Check also the new power supply with the paper clip test.
Sir I Do it But IAM afraid Of Electrostatic Charge Damage my Mobo other Part If I Try To Remove Them. is There Any Way to work With PC components Without Anti static mat Or wrist band Because My house Has No Earthing Wire What should I do now?
